Tial 50mm BOV problem with Evo IX
Old Jan 22, 2011 | 07:38 PM
achilles3000's Avatar
Originally Posted by 06MREvo
That's not necessarily true...I am using a 10 psi spring with a 1/4" reinforced vacuum line straight to the manifold with no Ts...My part throttle/cruising is actually pretty good. Its my a/f while cruising and at idle that is terrible.
Yours afr's are off??Is the bov open at idle?A good tune will solve this issu the maf need's to be scald correctly.
Originally Posted by EvoJoeIX
probably because the bov isnt fully closed and its messing up your fuel trims. the tial is not a good bov to run on a MAF, end of story
Not true ran it on my stock maf for two years it's all in the tune and you tuners ability!!
Originally Posted by Boost Demon
"1/4" reinforced vacuum line" is fuel line acceptable? What does it look?
Yes as long it's 1/4 id/od.
Originally Posted by MarylandEvo
Hey all,
I'm having an issue with my 50mm Tial BOV. When trying to maintain a speed, lets say 50mph, when I let off the gas, the car surges and doesn't blow off as it should. I've taken the BOV and greased it, only to have the issue come back a few days later. Any ideas on what the issue could be? Also, I wanted to note that when the engine is cold upon start up, the BOV will surge under ANY level of boost until the car is fully warmed up. I took the BOV fully apart today and noticed that I have the standard unpainted spring. Apparently there is no way to adjust this BOV without purchasing another spring.
MODS LIST:
- DC sports downpipe
- Burschur catback
- AMS FMIC
- AGP LICP
- TurboTrix UICP
- Tial 50mm BOV
- EvoPowerMods external o2 dump
- Forced Performance 18psi wastgate actuator
- Turbo XS MBC
- Buschur Racing ported stock exhaust manifold
- Aeromotive high flow fuel rail
- Precision 1000cc injectors
- Warlboro high pressure fuel pump
- ACT street disc clutch
- ACT LightWeight flywheel
- ProSport Gauges (Boost, AFR, Oil pressure)
Thanks for your help guys....
Danny
If you have maf and you put to soft of a spring you can get a check engine light!If you have stock cams then keep the unpainted and cut a coil off.
Old Jan 22, 2011 | 07:48 PM
06MREvo's Avatar
As far as I know its closed at idle...trust me everything is scaled as it should be...vta bov + stock maf = no bueno...All cars are different and mine hates it...
Old Jan 22, 2011 | 07:57 PM
Very true every car is different like my car doesn't like lots of * even at one point when I had meth didn't even like that too..
What spring do you have?? Is it the 50 bv or q ??I'm think of trying the black spring on my original.
Old Jan 22, 2011 | 08:04 PM
06MREvo's Avatar
Tial Q, 10 psi spring, perfect spring, 8 psi was way too soft & 11 psi is too stiff...
Old Jan 22, 2011 | 08:07 PM
Do you hear it blow of at wot loud or quiet?You think ill be better of with the black spring vs the white im on s.d?If you know anyone who wants to buy my q lmk good deal like new 500 miles.
Old Jan 22, 2011 | 09:17 PM
EvoJoeIX's Avatar
bottom line is this is not a good blow off valve to run on a MAF... i dont care if you can tune around the problems to make due
its gonna be very hard to keep the valve closed at idle, have good drivability(i.e. no bucking and surging) and have the valve able to open fast enough when you lift off the throttle so it doesnt have any flutter... the only way to get around this would be to go on speed density, then all you really have to worry about is having the right spring in there to not get any flutter
i am on MAF and run a tial. i have tried every spring they make, even shimmed some springs to make some different spring pressures... i have accepted the fact you cant make this bov perfect on MAF
Old Jan 23, 2011 | 08:14 AM
Never had issues with ,ine on stock maf from surging or flutter..I agree about choosing springs it's pain in the butt to find the right one..Im having the same issue choosing between the white or black now..Tial should charge $250 and include all the springs so everyone can pick the right one without spending pointless money on springs.
Old Jan 23, 2011 | 09:18 AM
evolvd276's Avatar
tial Q alpha since you already have the tial flange
Old Jan 23, 2011 | 09:22 AM
EvoJoeIX's Avatar
i agree with that. at $30 bucks a spring, it adds up
Old Jan 23, 2011 | 10:46 AM
unvyit's Avatar
im having the exact same problem with my tial blow off ,
Old Jan 24, 2011 | 07:26 AM
MarylandEvo's Avatar
Thanks, I forgot when I asked about what BOV's you guys recommend that I have the after-market UICP that is flanged for a tial.
Are you sure Tial Q Alpha won't have the same issues as my 50mm Tial did with regard to flutter and surging? Tial BOV's aren't cheap (as we all are aware lol)
Thanks,
Danny
Old Jan 24, 2011 | 07:27 AM
Originally Posted by ssg_petty_210
Ok, check your vacuum, and see about getting the correct spring. I would look into a retune with the right one. You should not be having the issues you are having bro. If you have any other questions. Ask KevinD. He can help you out. He is a vendor on here. Evolution Dynamics.
Thanks for your help bro.
Old Jan 24, 2011 | 04:34 PM
EvoDom's Avatar
The car was my car before Danny purchased it. The car was tuned with the tial and my tuner made the car easy to drives possible. I never had one problem at all with surging, idle, etc it was perfect. So something had to have went wrong.
Hope this helps
Dom
Old Jan 25, 2011 | 05:27 AM
Hope this helps
Dom
Thanks Dom. I don't have any issues at idle, just what was stated on my first post to this thread.
My new White Spring should be here tomorrow, I'm gonig to install it this weekend and see what happens. If it doesn't work, I'll look into getting a Tial Q Alpha. I'd like to think there's nothing wrong with the 50mm Tial that I have now, especially since other people are reporting similiar issues.
Old Jan 25, 2011 | 11:32 AM
ODUB's Avatar
Synapse DV...do it
