Fog lights wont come on.
Old Jan 29, 2011 | 05:07 PM
edsct9a's Avatar
So my fogs arent coming on. Ive tried checking fuses and all seem to be good. Besides under the hood and drivers side, is there anywhere else they are located? I used a wire and applied power from where the running light fuse to the fog light relay is and they come on that way but not by pressing the button in dash. Tried swapping relays and still no luck. Any suggestions?
Old Jan 29, 2011 | 05:15 PM
fugiwara's Avatar
did you check the bulbs?
and also check the switch... could be bad switch
Old Jan 29, 2011 | 05:29 PM
edsct9a's Avatar
Bulbs are good. I can get them on jumpering power from the parking lights.
Old Jan 29, 2011 | 05:49 PM
4RETECH's Avatar
You need to check apply power to foglamp switch that is controller by the headlamp switch.
In other words:Check the foglamp switch for power, when you turn the headlights on
Old Jan 29, 2011 | 06:43 PM
edsct9a's Avatar
Ok, so Im going to shoot for power at the switch if Im not mistaking?
Old Jan 30, 2011 | 12:34 PM
awdordie's Avatar
More than likely its just the switch. There's a good write up in the how to section on how to re wire the fogs into your parking lights on its own circuit where u can run with them on with just parking lights, low beams, or high beams where all three lights are illuminated. I recently did this andit looks great and really improves visibilty when the high beams are on.
Old Jan 30, 2011 | 06:22 PM
edsct9a's Avatar
Im going to have to look into this. Thanks.
Old Jan 30, 2011 | 06:28 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
relay?
Old Jan 30, 2011 | 06:33 PM
edsct9a's Avatar
Tried swapping the relays around and nothing. Are there relays anywhere else besides the engine bay?
Originally Posted by Skylineracer
relay?
