hks cams?
Old Feb 1, 2011 | 03:47 PM
svt_lightning01's Avatar
hks cams?
okay so i bought a 2005 mr. Still has fidanza cam gears and hks 280 cams however at idle i hear no lope. Can these cams be tuned to a smooth idle with no apparent change in engine lope than stock? just curious
Old Feb 1, 2011 | 03:57 PM
awdordie's Avatar
Yes. Its all in your timing and the tune. I run 272s with 5 degree retarded timing and they stomp the ground. Alot of people on here for some reason love stock idling with cams I however don't imo.
Old Feb 1, 2011 | 04:16 PM
evo8426's Avatar
though you have a evo 8 ive never heard one with cams that didnt sound like it had cams but ive got a 9 with kelford 272s and you cant tell i have cams other than after the car is completely warmed up and been ran to hell and back
Old Feb 1, 2011 | 04:21 PM
awdordie's Avatar
^ mine sounds stock until warmed up as well after the rpms drops below a thousand or around 1100 is when it starts loping. The car idles around 850 so that's another reason the cams lope so hard. Like I said its in the tune.
Old Feb 1, 2011 | 05:37 PM
okay i figured that they could be tuned to have idle factory sounds i was just curious
Old Feb 1, 2011 | 05:43 PM
JonahEVO's Avatar
Are you sure you got cams on there?
Old Feb 1, 2011 | 05:45 PM
johnny's Avatar
Registered User
does your evo have a stock ecu?
Old Feb 1, 2011 | 05:50 PM
Yeah. The car may still idle lope i let it run one day before i bought all of the parts but the radiator was busted so it may not have ever idled down correctly i'm not sure. But the timing cover was gone and it definitely has the fidanza cam gears. ttp said they put those gears and hks280 cams in it. I didn't figure anyone would go through the trouble to take off the cams and leave the gears. but the car is getting the radiator along with the ac condenser put on this weekend so i am pretty certain it will be 100% mechanically by the weekend so i can take it down the road maybe it idles down and lopes after i drive it awhile who knows.
Old Feb 1, 2011 | 05:51 PM
ill be honest i have no idea what an aem ems is? Im still learning the lingo and the basics about the car.
Old Feb 1, 2011 | 05:52 PM
ch1215g's Avatar
SUSPECTED SCAMMER
i got hks cams and i got absolutely no lope whatsoever!
Old Feb 1, 2011 | 05:55 PM
the car was worked on by ttp engineering. They did a walbro pump, hks280 cams, fidanza cam gears, hallman controller, open filter intake, turbo back exhaust, and i think thats all that was done to the car. i know the boost controller is no longer there. as far as i know everything else is still there. I am going to go with a greddy profec2 ebc as soon as i can get the car on the road. They said they did a plug port tune to the car down there but it was a direct ecu tune. It doesnt have a programmer.
Old Feb 1, 2011 | 05:56 PM
should i call ttp and ask them what psi the tune was at WOT? right now i just looped the system back for stock boost until i get a controller. i figured i should set it on whatever they tuned it for so it will run like it should?
Old Feb 1, 2011 | 06:09 PM
johnny's Avatar
Registered User
i would definately do that
Old Feb 1, 2011 | 06:18 PM
okay as soon as i get her out of the paint shop i will give them a call
Old Feb 3, 2011 | 11:47 AM
awdordie's Avatar
The aem ems is an engine management system hence ems. It is a programmer but with so much more.
