do i need to replace my bov?
Old Feb 2, 2011 | 05:09 PM
bbak11010's Avatar
hey all,
I bought a car tuned at 345 hp 33x tq running 22 lbs of boost from a forum member here and it still has the stock bov. I've heard that stock bov will leak or not hold up when the car is modded. So I was wondering if I would need to replace it to an aftermarket one, or do i not need to worry about it with the current power?
Any help is appreciated!!
Old Feb 2, 2011 | 05:13 PM
grillpt's Avatar
Your stock diverter valve is fine. You have a IX, its not an issue at that boost level.
Old Feb 2, 2011 | 05:21 PM
bbak11010's Avatar
thanks grillpt!
Old Feb 7, 2011 | 02:27 PM
nismos13sleeper's Avatar
yea they acctully hold up pretty goodd. its either there bad once ur at like 300 horse or they hold up for more. a buddy had mild mods was around 300 and his went bad. then i knew people like in ur case with 330-350 and it worked fine with higher boost.
Old Feb 7, 2011 | 02:31 PM
PKEVO8's Avatar
you can also crush your stock dv to hold moar boost, if/when you decide to do more mods.
Old Feb 7, 2011 | 02:35 PM
milford's Avatar
+1. mine was starting to open at 24 psi, i crushed the cap and tested to 30 psi with 0 leak.
