wheel hop elimination ?
i have a stock suspension mr i am finishing my motor build and will be back at the track.
with stock block/turbo i would spin out of the hole no wheel hop although i did hear some clunking in the rear a few times .
i am wondering what i have to look for with a built motor and larger turbo coming off the line with stock suspension?
any advice / help thanks in advance
The clunking was probably your rear diff banging around, Beatrush and Energy make urethane bushings that are a nice upgrade. Beatrush and Torque Solution also make some aluminum driveshaft bushings that can help. For a front engine mount check out the Blox, it's not too expensive and a very nice piece.
I searched this before and found a lot of people having success with lower tire pressure as well as the things Kracka mentioned. Front mount (i Used Torque Solutions) helped me as well.
