Heater Issue
Old Feb 19, 2011 | 11:20 PM
High_PSI's Avatar
Heater Issue
I am having a new issue with my heater. I have to put the knob (the one that has Blue/Red, all the way into the red, as far as it will go, to get heat. It is very hot there but if I turn it back at all it becomes much cooler, it is either really hot or not.
Any ideas?
Old Feb 20, 2011 | 08:55 AM
jackbenimbo's Avatar
If I'm not mistaken, I THINK this problem's been answered if you search but if not I believe you need to replace the HVAC controls. Your not having the common issue of 'knobs are hard to turn left and right' are you ? That's a common issue on lancer/evo's...had it on my 03 VIII and now as well even on my 05.
Old Feb 20, 2011 | 09:09 AM
High_PSI's Avatar
No sir, mine is an 06, I think teh knob may have just went? Who knows.
Old Feb 22, 2011 | 07:05 AM
High_PSI's Avatar
BUMP. The car blows cold air when started and left to idle. When I drive off and hit the gas it gets hotter. Could it be my thermostat? The car's engine temp on the dash sits at half.
Old Feb 22, 2011 | 07:14 AM
Jrah2987's Avatar
Veteran: Air Force
When you push it all the way hot, does it make a little clunk noise as if the door had to be forced open or is there no resistance?
Old Feb 22, 2011 | 07:16 AM
High_PSI's Avatar
Not at all, I have an 06 MR so they fixed that issue, it turns fine I believe. I hope it isn't broken. This is a new issue, just started.
Old Feb 22, 2011 | 07:22 AM
evoalan's Avatar
i had the same problem. look under the dash there is a white thing that have a cable hook to it. when u turn your heater on it should be up and when the air is on it should be down. make sure that cable isnt broke. you have to turn the kncb to hot and look under the dash and see is that white thing is working because that thing control the heat and ac
Old Feb 22, 2011 | 07:37 AM
Bobster22388's Avatar
You have an VIII, how could you have the same problem as him when he has a IX?
Old Feb 22, 2011 | 07:46 AM
evoalan's Avatar
i had the same heater problem on my evo 8
Old Feb 22, 2011 | 11:33 AM
barneyb's Avatar
Thermostat
Old Feb 22, 2011 | 05:10 PM
evoforstevo's Avatar
i have a similar issue except i was told my heater was replaced aka the dash was ripped out and they put a new one in... idk if i trust the place or not but my heater has moods. when i drive fast its cold... when i don't it still can be cold but may have some minute warmth to it....its -20 degrees as of right this second in the tundra i live in so anyone have any advice? thermo has been replaced too
Old Mar 30, 2011 | 12:30 PM
overdrive1's Avatar
I have this same issue. It doesnt get hot unless its all the way to the right and it stays at full heat, unless I move it almost all the way back to cold and then its full cold. There is no mid setting, its either all cold or all hot. this is an Evo IX GSR.
Old Mar 30, 2011 | 06:48 PM
craig05evo's Avatar
I am leaning more towards an air bubble in your system. Have you had any work done to the cooling system? Air bubbles can wreak all sorts of havoc, but are fairly easy to fix.
Old Mar 30, 2011 | 07:43 PM
brand0n's Avatar
What's up guys! i use to have this same problem, here are some pics to show u how to do a quick fix.
Old Mar 31, 2011 | 08:55 AM
sho669's Avatar
This sounds like an air pocket in the cooling system, t-stat could be getting a little lazy as well though.
Any work done on the car recently?
