Update guys!!!! Last lil bit of help needed
Old Feb 26, 2011 | 02:48 PM
svt_lightning01's Avatar
Alright guys I got the mbc boost gauge and air fuel in the car and she is running good. A few little problems I could use some help with. First off the aem uego reads 14.8 all the time no matter what. I'm gonna check the connections I just wasn't sure if this was a common problem that you guys have had. Second it throws two codes : random misfire and iat sensor high output. Just replaced the plugs too. Thanks for the help guys.
Old Feb 26, 2011 | 03:20 PM
chaotichoax's Avatar
search around for the P0300 code...plenty of random misfire information on here...it's been discussed a million times
here is a video explaining the uego sensor...watch it
http://www.youtube.com/watch?v=1mb4VmDd0ao
Old Feb 26, 2011 | 04:07 PM
I'll watch the vid when I get off work but from what I read it sounds like the misfire is common in evos? It only burps and idle and I feel no mis what so ever in a pull or spool up
Old Feb 27, 2011 | 04:06 PM
I watched the video. I didn't do that test yet however I read you can turn your key to the on position and the gauge should lean out to "---" if it's reading correct however mine stays at 14.8 for up to five minutes and still no movement. You think either a dud o2 sensor or bad connection between o2 and the gauge?
Old Feb 27, 2011 | 09:39 PM
Anyevowilldo's Avatar
mine never stays constant it fluctuates between 14.8 and 15.2 even at idle...
