Car died this morning driving to school
Old Mar 11, 2011 | 10:34 AM
Tfresh's Avatar
Ok I swapped out my HKS DLi for a spoolinup COP. The car started up right away and idled great after letting the car warm up I then started to drive to school. It started moving fine no sputtering or anything and I got to the end of the street and it died at the stop sign. The car cranks but it wont catch, also the fuel pump does run when I turn the key in the on position. I swapped out the COP for the stock ignition there and it still wont start. Any suggestions?
The car has:
IX turbo
AEM EMS
Kelford 272
QTP o2 dump
Invidia TBE
Old Mar 11, 2011 | 10:42 AM
sho669's Avatar
Check you ignition fuse, its located in the under dash fuse panel. top left, should be a 10A, should swap it out with a 15A when a COP setup is installed.
Old Mar 11, 2011 | 11:20 AM
Tfresh's Avatar
I just checked the fuse and it was blown. I will have to run to the parts store and get some more fuses and I will try the 15A
Old Mar 11, 2011 | 07:17 PM
Tfresh's Avatar
Swapped the fuse out and the car fired right up thanks for the help
Old Mar 11, 2011 | 07:33 PM
Aaron20's Avatar
I love easy fixes!!!!!!!!!!!
Old Mar 11, 2011 | 09:13 PM
sho669's Avatar
The best kind!
