Is this boost leak?
Old Mar 20, 2011 | 07:20 PM
bbak11010's Avatar
Is this boost leak?
hey all,
I was wondering if I have a boost leak or is this normal.
I have a defi boost guage and at idle it reads -10 lbs. But the moment when I engage the clutch to shift up while driving, the meter goes down to -20. I'm curious to know if this is normal or if I need do do a boost leak test.
Any help is appreciated!Thanks.
Old Mar 20, 2011 | 07:28 PM
binky's Avatar
Originally Posted by bbak11010
hey all,
You should do a boost leak test anyway. It's always good to make sure everything is tight and that there are no leaks.
Realistically, it doesn't take long to do the test. The hard part (might) be fixing the leaks.
Also, FWIW - some leaks you can't notice and in your case, even if you could tell (tell tale sign is loss of power, spool up and over-boosting) you would have to be in boost (greater than 10 PSI, not in the 'negative' (vacuum) region to which you were referring).
-Bink
Old Mar 20, 2011 | 07:30 PM
L@Ncer06's Avatar
that is vacume and if you idle is getting rough you might have a vacume leak but i tto would suggest a boost leak test not hard to do at all good luck
Old Mar 20, 2011 | 07:33 PM
ev1levo's Avatar
where can i get the parts ONLINE for a boost leak tester?
Old Mar 20, 2011 | 07:34 PM
limp_noodle's Avatar
You can go to home depot and buy everything from there.
otherwise check this out:
http://www.siliconeintakes.com/index...eeace4c9223499
Old Mar 20, 2011 | 07:36 PM
ev1levo's Avatar
^ Alrite thanks a lot, also i would put this directly on my turbo? whats the inlet size on a fp black? 3.25?
Old Mar 21, 2011 | 01:21 PM
bbak11010's Avatar
thanks all, Ill go ahead and do a boost leak test soon.
Old Mar 21, 2011 | 01:24 PM
ev1levo's Avatar
^^bump for an answer!
Old Mar 21, 2011 | 04:22 PM
EVO8emUp's Avatar
hey all,
This is completely normal. The higher rpm of the engine + closed throttle plate produces greater vacuum than at idle.
