help me with a selection s1 vs s2...please
Old Mar 20, 2011 | 07:24 PM
shifthard's Avatar
Thumbs up help me with a selection s1 vs s2...please
I have a 2006 evo se. I have full Cobb turboback, arc intake, stock 9 bov, ams mbc set to around 21 pounds, Muse licp. I'm still confused on which cams to get. Gsc s1 vs Gsc s2. I've read most of the threads on them. How s1 works better on stock turbo and no loss in the low end and s2 sacrifices low end for top end. I'm still on stock turbo and maybe planning to go bigger later on but still undecided. But I've seen people with bigger turbos also run s1 and stand by it. And i was told I can run stock springs on the s2 as long as its only revving within stock range. I'm only doing cams once and wont change them again. Will I be okay running the s2 on the stock 9 turbo for now until I(if) go bigger Turbo. Or should I go s1 now and then just keep running it even if I go with a bigger turbo? Will I be okay if I kept stock turbo and just run the s2? Help me lol.
Old Mar 20, 2011 | 07:36 PM
sho669's Avatar
I would run S2's for sure. Check this out: https://www.evolutionm.net/forums/ev...tle-turbo.html
Lots of info in that thread. I was going to use S2's but decided to go with a BIG turbo so S3's were my answer.
Old Mar 20, 2011 | 07:43 PM
The Storm's Avatar
I am running the S1's in my IX with a stock turbo and love them. It pulls hard down low and doesn't stop, I go to 8k and it pulls all the way. I don't have any experience with the S2's so I can't speak for them. I don't regrett my choice.
Old Mar 21, 2011 | 02:09 AM
Redline06's Avatar
Am still on GSC S1's on my FP Red and the cams are still sufficient. They will work superb pushing the stock turbo to its limits. Infact even stock cams can be used to push the stocker.
Old Mar 21, 2011 | 02:13 AM
EVO_N9NE's Avatar
s2 if you'll go bigger =]
Old Mar 21, 2011 | 06:54 AM
Ryuartz's Avatar
Sorry, How about evo 9 cam vs GSC 1? How much gain?
Old Mar 21, 2011 | 07:13 AM
xmaciek82x's Avatar
Is cost an issue? If you go with S2, you need to install springs. S1 you do not. If you are having someone do the work, the labor rate will be significantly higher.
Old Mar 21, 2011 | 07:17 AM
shifthard's Avatar
I saw a post from a tuner explaining how the s1 post the same kind of power line as the stock sticks but just lifted higher in the dyno graph. So power is gained throughout the whole rpm band.
Old Mar 21, 2011 | 09:44 AM
steelfire19's Avatar
S2s are very impressive and relatively affordable.
Old Mar 21, 2011 | 09:46 AM
JohnBradley's Avatar
S2 has no loss in low end on the Evo IX. Its the beauty of MIVEC when done properly hides anything that might be negative.
Here are some dyno graphs to show what I mean-
https://www.evolutionm.net/forums/ev...370ft-lbs.html
Old Mar 24, 2011 | 09:58 AM
shifthard's Avatar
Thanks for the input guys. I went and ordered the s2 with headstuds and tune.
Old Mar 24, 2011 | 01:38 PM
evil.evo's Avatar
Veteran: Army
FCOTM Winner
so, the s2's are better than the s1's in every single way except that it can be more expensive due to having to run aftermarket springs and retainers?
Old Mar 24, 2011 | 01:43 PM
kyoo's Avatar
good decision - fwiw i wish i went with s2's in terms of longer term plans w car
Old Mar 25, 2011 | 05:25 AM
Paintballguy's Avatar
I'm going to be running S2's on my stock 9 turbo.
Old Mar 25, 2011 | 05:53 AM
Bobster22388's Avatar
If your only doing cams once as you've stated I'd do some springs and retainers at the same time. That way you don't have to worry about your RPMs and GSC recommends you do them with the S2's
