Just installed EPM o2 dump, now only boost 20psi?
Old Mar 25, 2011 | 03:06 PM
jnut24's Avatar
I just installed the EPM o2 dump and went to test drive the car and my boost gauge is only reading 20psi on WOT, but the car still pulls hard. Any idea why this is happening?
Old Mar 25, 2011 | 03:20 PM
MR. EVO MR's Avatar
fyi my epm broke in 2. you should get a tune
Old Mar 25, 2011 | 03:31 PM
jnut24's Avatar
I am goin for a tune in a couple weeks
Old Mar 25, 2011 | 04:32 PM
xmaciek82x's Avatar
What was your boost before?
Old Mar 25, 2011 | 06:54 PM
jnut24's Avatar
I'm tuned at 25psi gauge only wants to go to 20psi
Old Mar 25, 2011 | 07:00 PM
sharkm87's Avatar
what are you using to control boost?
Old Mar 25, 2011 | 07:47 PM
jnut24's Avatar
Hallman pro
Old Mar 26, 2011 | 04:51 AM
vortecd's Avatar
Boost is back pressure. The new 02 dump freed up some of the restiction of the exhaust system. Would be the same if you had a 2" exhaust system then went to a 3". Your boost would go down but you would actually be making more power.
Old Mar 26, 2011 | 07:06 AM
jnut24's Avatar
That makes sense.
Old Mar 26, 2011 | 08:14 PM
aka.ralliart15's Avatar
Mine does the same thing, still haven't figured out what it is but my tuner says it's an exhaust leak.
Old Mar 26, 2011 | 08:50 PM
sparky's Avatar
Did you go from the stock, cast iron, factory O2 housing to the EPM dump? What is your complete modlist?
Old Mar 26, 2011 | 08:53 PM
sparky's Avatar
What gear are you reading the 20# peak in?
Old Mar 26, 2011 | 09:00 PM
sparky's Avatar
What happens if you try and crank boost back up to the 25# level with your MBC?
Old Mar 27, 2011 | 08:58 PM
jnut24's Avatar
20psi at wot in every gear haha... I did turn up the mbc and gauge moved 1 psi. So now it's 21psi, I'm guessing that it's a good thing my gauge is still able to move after adjusting my mbc
Old Mar 27, 2011 | 09:03 PM
jnut24's Avatar
Also my mod list is
Gsc s1
EPM o2 dump
Bushur tbe
Ets 3in intercooler
Ets intercooler piping
Tial bov
Hallman pro boost controller
Walbro 255 fuel pump
Hks intake
BEISSEN
Jan 23, 2011 01:31 PM
brandEvO
Aug 18, 2009 10:28 AM
6-speed
19
Mar 21, 2009 04:40 AM
DDATuned
Mar 12, 2009 01:56 PM
DDATuned
Jan 30, 2009 07:02 PM
