Throttle position sensor adjustment
Old Mar 31, 2011 | 06:29 PM
rayman0690's Avatar
Alright, here's my story. And I've searched a good bit.
Got into EvoScan today and noticed that at idle or even with the car off and no pressure on the gas pedal...the throttle position was at 14%. So I get home and loosen the screws on the throttle position sensor and move the sensor until I got a value of 4%. Now, no matter how much I play with the sensor or the throttle cable itself, I can't get a 0% at idle/no pressure. When I push the throttle to the floor, I only register 95% throttle.
Any ideas? Do I need to clean the thing somehow. I read in EvoScan under the "Throttle Position Sensor" section that:
"Displays state of the throttle. High voltage or % value means a more open throttle. When logging engine activity (especially on the dyno), it is useful to log throttle position. This makes it easy to see when a power run begins and ends i.e. when the driver's foot is depressing the accelerator fully. Some mitsubishis show up to 20% when your foot is off the accelerator, and will show a max of 90-99% when your foot is fully applied, this is normal."
So...my question is, am I ok with the current values? Or do I need to make sure I can register 100% throttle position when at WOT. Will this cause problems on the car in calculating load and it's AFR's? I am going to be tuning soon and want the car to be operating properly beforehand.
Old Mar 31, 2011 | 08:42 PM
BLK_EvIL's Avatar
i know that mine reads like 11.xx% at idle and iv been told that was perfectly normal i just made so i get 100% at WOT while still being the lowest % at idle
Old Mar 31, 2011 | 08:48 PM
wizzo 8's Avatar
+1. Adj it so it reads 100% at wot. Idle wont read 0%
Old Mar 31, 2011 | 09:32 PM
Sacevo9mr's Avatar
I have never tested myn at idol, but i got some weird number like 38% while under full boost last time i was tuning :/
Old Mar 31, 2011 | 09:33 PM
rayman0690's Avatar
Thanks guys. Guess I just had my target logic backwards. I was aiming for 0% at idle rather than the 100% at WOT. I'll adjust it properly!
Old Apr 1, 2011 | 10:27 AM
barneyb's Avatar
Yeah, you will never get it to read perfectly 0 to 100%, it is after all a piece of carbon. So, set it to 100% and check for any dead spots. Dead spots require replacement.
Old Apr 4, 2011 | 05:17 AM
bruce988jl's Avatar
Just wondering but I have mines set to 12.9% right now at idle, I was wondering how people are checking their tps sensors for dead spots?
Old Apr 4, 2011 | 06:13 AM
barneyb's Avatar
I've never had reason to touch the one on my Evo, but if it is like the ones on other vehicles I have worked on, you mark its position, pull it, connect a VOM set to ohms and rotate it through its range of motion watching for a steady increase or decrease in resistance. If resistance suddenly goes to infinity, you have found a dead spot.
Old Apr 6, 2011 | 08:39 AM
bruce988jl's Avatar
ahh alright I'll give that a shot. Thanks a ton.
tephra
Jul 25, 2016 02:21 PM
LeXcite
Dec 5, 2015 02:33 AM
evo4mad
May 5, 2015 06:22 PM
Jamesm331
Feb 29, 2012 08:32 AM
