is it nessecary to upgrade rods? evo8
Old May 8, 2011 | 05:30 PM
Chan-Evo8's Avatar
I heard the rods are forge is it nessecary to upgrade the rods and just put forge piston.thinking about cosworth pistion in the build Eny help?
Old May 8, 2011 | 05:42 PM
awhitesti's Avatar
Lol, yes. Unless you don't mind a rod coming through your block eventually.
Old May 8, 2011 | 05:44 PM
GEJEN's Avatar
yes...
Old May 8, 2011 | 05:47 PM
Chan-Evo8's Avatar
I know it Was a stupid question but thanks for the info.
Old May 8, 2011 | 05:48 PM
Piro Fyre's Avatar
From reading the "How to build a 4G63" book, it's recommended to replace them.
Actually, it's cheaper to just buy better rods because you would need to get the stocker machined, which isn't worth the cost compared to the better rods.
Old May 8, 2011 | 05:56 PM
GEJEN's Avatar
where in ga are you?
Old May 8, 2011 | 05:58 PM
Chan-Evo8's Avatar
Marietta
Old May 8, 2011 | 07:02 PM
neonglh's Avatar
That usually happens from the rod bolt going, not the rod itself....
Old May 8, 2011 | 07:14 PM
awhitesti's Avatar
stock rods are still gonna cause problem eventually... but yes thats usually due to the bolts.
Old May 8, 2011 | 07:50 PM
4RETECH's Avatar
Highly recommend putting new rods in while you are there. Depending on your power goals though.
If you want to keep it stock, sure. But if you want to do what every person on this board does........Get rods... You will eventually need them.
