Making the jump to SD and have ?'s
Old May 31, 2011 | 09:24 PM
canitbethislong's Avatar
I was once planning on using AEM. So I sold my stock ecu.
I have been reading the tephra and ecuflash wiki's and searching on google for a few days now. So now I am trying to figure out how to get rid of the immobilizer on the stock ecu I bought.
Im also searching for the wiring of the IAT and MAP.
This stuff is pretty complicated, which I may be making it that hard because of my over analytical personality haha.
Thanks again for anyones help.
Old Jun 1, 2011 | 05:04 AM
JakeTheVIII's Avatar
http://evoecu.logic.net/wiki/Immobilizer_Disabling
just have to disable it (set from 1 to 0) in the periphery bits
Old Jun 1, 2011 | 09:37 AM
Lol...must have skipped that section oops! Thank you a ton.
Anybody else on other questions please!
Old Jun 1, 2011 | 09:42 AM
05blue8's Avatar
They sell a harness that is all wired etc so you can go back and forth...
Old Jun 1, 2011 | 09:45 AM
teribble's Avatar
You should talk to Arron at English Racing. They do their SD a little different from others and it seems to work very good. I'm in the process of doing mine. I'm sure you can pm him and get a price for a base map, maybe even get a e mail tune. It just requires a omni 4 bar map sensor.
Old Jun 1, 2011 | 09:56 AM
Im running the aem iat and aem 5 bar. I will shoot him a few questions.
I dont want to run a harness someone else made, even though some of them look nice. I want to see how the stock ecu works on sd and if I like it. If I do then I plan on making a custom harness cause the mitsu one looks like a rats nest.
Old Jun 1, 2011 | 10:26 AM
teribble's Avatar
check out http://spoolinup.com/ He makes very nice harnesses.
Old Jun 1, 2011 | 12:19 PM
He just means an additional harness for the sensors to avoid having to splice and wire the sensors yourself. Not a whole new engine wiring harness. I have the spoolinup speed density harness from the link above, haven't gotten around to installing it but it looks great.
Old Jun 1, 2011 | 12:53 PM
EvoJoeIX's Avatar
ditch the IAT sensor and go off of the fuel temp.... much much easier and no wiring or IAT sensor needed
this is how my car is set-up and i love it. drives perfect and didnt need anything besides an omni 4 bar sensor
Old Jun 1, 2011 | 02:59 PM
Yeah I got what he meant, and that piece is what I meant I dont wanna buy. Anyone have which wires or pinouts to use on this would be helpful.
Old Jun 1, 2011 | 03:14 PM
wizzo 8's Avatar
Where is the fuel temp sensor? How do you tap into it?
Old Jun 1, 2011 | 03:16 PM
Yeah Im kind of curious to this...
I already have the iat and its worked for years on other setups so why fix what aint broke for right now.
Old Jun 1, 2011 | 08:17 PM
Kept on plugging away at it. If you dont know how to wire it and are needing help and happen to find this thread I will post the links I found helpful below. Thanks again to the others that did help
https://www.evolutionm.net/forums/ev...d-density.html
Old Jun 2, 2011 | 12:55 PM
EvoJoeIX's Avatar
you dont need to do anything, you just select it when your setting up the ecu
its not about fixing anything, its just a lot easier to set-up this way instead of messing with putting a IAT in. its also cheaper... either way will work
Old Jun 4, 2011 | 10:38 AM
Trying to figure out what fuel temp has to do with it though?
