Pump going bad in my Double Pumper?
Old Jun 14, 2011 | 08:18 AM
rodent's Avatar
Last week I was driving on the highway going up a slight hill doing the speed limit. All the sudden the car starts to break up a little and I notice my fuel pressure gauge isn't normal. It gets worse and I had to pull over and the car finally died. It was only showing 23psi when it died. My gas gauge showed 1/4 of a tank. I just so happen to have a 5 gallon can of E85 in the trunk so I poured that in the tank. After that, the car started and I had normal fuel pressure again. I haven't had the problem since but I've also kept a full tank.
I'm wondering if thats a sign of one fuel pump going bad? When one pump goes bad, how does the gas flow? Does it back flow through the bad pump causing lower fuel pressure?
The fuel pumps are probably 5 years old so I'm thinking about replacing both.
Old Jun 14, 2011 | 08:30 AM
metalsaber's Avatar
Quite possible. Or the gas gauge isn't reading right.
Old Jun 14, 2011 | 08:39 AM
prockish_03evo's Avatar
Yea 5 years on walbros is alot haha... or ive read here that the double pumpers dont do well when they are at or under a 1/4 tank. I guess they fight each other for volume.
Old Jun 14, 2011 | 10:45 AM
rodent's Avatar
Good to know. A week before I ran the tank to almost empty with no issues. After filling the tank with the 5 gallon can, I used another 7 gallons at the pump to fill it up. So that would make it 12 gallons I added to the tank. The stock tank is 14 gallons so I don't think I was out of fuel.
Anyone else had a pump go out on a Double Pumper?
Looks like I'll be replacing them this week.
Thanks!
Old Jun 14, 2011 | 11:46 AM
rodent's Avatar
Also, what pumps does the Double Pumper take? GSS340 or GSS342? I know they are modified with the plunger pushed in at the top. I may just order them from Buschur but I happen to have 2 brand new GSS342 pumps with socks.
Old Jun 14, 2011 | 12:40 PM
I believe they are GSS342 but i would just buy them from Buschur so he can do the high pressure mod to them
Old Jun 14, 2011 | 02:02 PM
rodent's Avatar
Thanks. After looking around looks like maybe they use GSS340.
http://www.norcalevo.net/threads/267...pumper-arrived
Nice pics including instructions.
Old Jun 15, 2011 | 07:59 AM
rodent's Avatar
Went ahead and ordered 2 new pumps from Buschur which included the tubes / socks. Price was very fair and Nick got me taken care of.
Old Jun 28, 2011 | 10:15 PM
project_skyline's Avatar
David sad older doubles don't even have the pressure mod done to the pumps unless when you order them you tell em your running e85 so I'm betting yours weren't modified just like josh's pretty sure aren't either.
Old Jun 29, 2011 | 07:14 AM
rodent's Avatar
I'll check that when I take out the old pumps. I haven't had time to do anything on the car with all the house projects going on.
