Multiple PLX sensors wired to ECU for Evoscan?
Old Jun 17, 2011 | 12:15 AM
gallas's Avatar
ok i have PLX boost, AFR, EGR, and oil temp sensors. I have the AFR wired to the stock O2 sensor on the evo ix ecu so i can log correct afr while im in evoscan. now i have these new sensors all installed and have searched around and read threw plenty of evo ix ecu pinout forums and diagrams but cant quite seem what pins i can use for boost, oil pressure, and EGT... does anyone have any ideas. is it possible to use a empty pin on my ecu and try to find a diagram that shows the address of the empty pin and just make some changes in evoscan?? It would be really nice to be able to log everything with evoscan, instead of two different software programs running to log two separate settings lol...
Old Jun 17, 2011 | 02:26 AM
gallas's Avatar
could i cut the Map sensor and attatch the PLX boost analog to? or is map not what the evo uses for logging boost?
