Sabrina's Got Wood!!!
Old Jun 27, 2011 | 11:29 PM
  #46
sabrinaEvo's Avatar
Originally Posted by EVO8emUp
Once you get plywood on the sides, those ramps will be solid!
Don't forget to cut a couple ovals in the plywood for handles. Makes moving them much easier.
I use (2) 2x6 x 30" long (pine) and place them about 3/4 of the way up my Rhino Ramps w/ no support in the center. You cant even see the 2x6 flex.
I'd make a couple supports for the ramps, drill a hole through the last vertical on the ramp section, into the first vertical on the flat and use a 1/2" bolt w/ washers and a wing nut to temporarily secure the two when moving the car.
I was thinking of utilizing bolts in my design. My first idea was having temporary cross members from left to right to ensure the distance between the ramps are even and square (kind of like the pics in the Corevette site but adjustable for different cars). The second was to secure the two portions on each side so they act as one piece.
I like the idea of having the ramps bolt on to the main assembly, so that's probably what I'll do. But I also want the ramps to be able to be easily disassembled to store underneath my car when the whole system is not in use.
Originally Posted by ArmedEscort
Some grip on the bottom plank would help too. There is a moment where the front wheels are on the ramp with power going to the wheels that might make the ramp move.
I thought about using some metal grates, but when I laid it out the slope is very tame. And I'm pretty sure if all 3 sections are bolted to each other, that ramp won't move because of all the weight and surface area which will be contacting the ground.
Old Jun 27, 2011 | 11:37 PM
  #47
BenJ's Avatar
I would imagine that with the angle of the ramp coupled with the static cof of the wood/floor that the ramp wouldn't slide, unless you hit it at high speed in which case you would have bigger worries lol.
Old Jun 29, 2011 | 02:38 PM
  #48
sabrinaEvo's Avatar
^^ +1. Maybe if I it at 88 mph I'll end up in 1955... Lol
Old Jun 30, 2011 | 01:33 PM
  #49
sk8elenex92's Avatar
Damn thats kinda IFFY. Looks like a great idea might make something on the CNC like this.
Old Jun 30, 2011 | 07:03 PM
  #50
sabrinaEvo's Avatar
It'll be ok. CNC would sure cost a lot of money. If I had my own house, I'd definitely spring for the all metal & hydraulic route... But this will do for now.
Old Jun 30, 2011 | 08:38 PM
  #51
EVO8emUp's Avatar
You don't have to worry about traction on the ramps. The 30" pieces I mentioned above are not secured in any way, just laying on the ramps and I've never had one slide on me.
Remember, the rear wheels are pushing the car forward, too. Plus, it's not like you're going to be engaging the aggressively.
Once I had my ramps in place, I made a few marks on the garage floor with a Sharpie to reduce future setup time.
A CNC seems like major overkill of precision, not to mention time, for ramps.
Old Jul 1, 2011 | 05:31 AM
  #52
sabrinaEvo's Avatar
Thanks for the advice Evo8. Maybe I'll make some triangles like rhino ramps which the 6 foot 2x6's will rest on. And maybe they can double up as wheel stops once the car is up on the ramps. I'll need to draw it out...
Old Jul 12, 2011 | 09:53 PM
  #53
sabrinaEvo's Avatar
Plot thickens...
Will be back home on Thursday - Sunday and hopefully I can get them finished on Thursday.
Also, I was looking at Race Ramps online today and saw their $2800 price tag... I'm glad I'll be saving myself $2500 dollars
Old Jul 12, 2011 | 09:58 PM
  #54
EvoTeyn's Avatar
Originally Posted by sabrinaEvo
Plot thickens...
Which ramps are you looking at? their standard ramps are like in the $300 range
Old Jul 12, 2011 | 10:39 PM
  #55
sabrinaEvo's Avatar
Portable Pit Stop
Old Jul 13, 2011 | 02:15 AM
  #56
EvoTeyn's Avatar
^ wow those are exspensive, plus seemed over priced. Good call on makin your own
Old Jul 13, 2011 | 03:49 AM
  #57
loneracer05's Avatar
I think I may do something like this when I get my evo back
Old Jul 13, 2011 | 07:23 AM
  #58
SikofFalln's Avatar
Nice, good idea for doing exhaust work.
Old Jul 15, 2011 | 12:48 AM
  #59
sabrinaEvo's Avatar
Got in today from Japan and started working on the ramp. I'd say it's about 90% complete. The last 10% is purely cosmetic and not detrimental to function. Will take more pics tomorrow when there's light out.
FYI. Wheel center to wheel center is just around 59 inches.
Attached Thumbnails Sabrina's Got Wood!!!-img_2062.jpg   Sabrina's Got Wood!!!-img_2072.jpg   Sabrina's Got Wood!!!-img_2075.jpg   Sabrina's Got Wood!!!-img_2076.jpg   Sabrina's Got Wood!!!-img_2081.jpg
Old Jul 15, 2011 | 12:52 AM
  #60
sabrinaEvo's Avatar
A few more pics...
Attached Thumbnails Sabrina's Got Wood!!!-img_2085.jpg   Sabrina's Got Wood!!!-img_2090.jpg   Sabrina's Got Wood!!!-img_2092.jpg   Sabrina's Got Wood!!!-img_2097.jpg
