How often does your Radiator fan turn ON/OFF?
Old Aug 8, 2011 | 01:50 PM
TxFAkuma's Avatar
Originally Posted by shinjuki
Does your fan run in during cold start as well? If so its ur fan control unit.
Had the same issue fan ran like crazy on and off also when the car was off it would run for another 2-3 sec and then switch off.
My car's fan JUST JUST started doing this last week. I turned the car off and it stays on for 3-4secs then it turns off... i was like "huh wtf" but didnt think much of it. Now i dont know what it is..seems like the controller unit huh.
Old Aug 9, 2011 | 12:05 AM
shinjuki's Avatar
Yep, its the fan control unit. Replace it.
Old May 8, 2012 | 06:31 AM
Sil'vr-Boi6's Avatar
Anyway to extended the life of the fan control unit? ...is it a moisture? or heat issue?
Old May 8, 2012 | 07:02 AM
bnr34rb26dett's Avatar
Is there a way to have the fan on constant on
Old May 8, 2012 | 07:14 AM
djikonatx's Avatar
yup. im sure you can do it like the civics. just put a wire connecting both ends where the temp sensor is and itll turn on.. im pretty sure its the same idea. i did that to my civic but i ran a switch into my car . that way i can control it.hope this helps
Old May 8, 2012 | 07:08 PM
bt1's Avatar
bt1
You would want to fix it rather than wire it to run all of the time. Having it run all the time just puts extra load and wear on the charging system. The fan should only run when the car is idling for long periods. Keep in mind that the second electic fan runs whenever the AC compressor is engaged.
Old May 8, 2012 | 07:12 PM
deadstockkpomp's Avatar
yes, the fans will go on/off at idle my 03 does the same thing it happens almost every 2-3 minutes at idle id say, its normal
Old Jun 12, 2013 | 04:59 AM
illogicalmind's Avatar
I want to jump in here for the sake of the thread. The fan turning on and off is because your AC is turning on and off. I noticed this today. If you hear your fan just turn on and off at idle look at your AC clutch. Its probably going with the fan. Turn off the fan blower inside your car and it will stop. Mine was doing this even with the AC off. I'm thinking its because I had the blower selection going to the windshield defroster and that automatically triggers the AC. I'm going to check that later today. Turn the vent selection to just out the top vent and make sure the AC is turned off. It should stop your fan from kicking on and off. Or just keep the blower off unless you need it.
JDavenport
Apr 29, 2017 12:43 PM
asu11
Aug 5, 2016 02:55 AM
MisUnderStood
May 12, 2015 01:57 PM
evo78
25
Aug 15, 2010 10:20 AM
MR. EVO MR
16
May 14, 2010 01:11 AM
