Idle problem
Old Jul 14, 2011 | 12:35 PM
turbotalawd's Avatar
Yes its a possibility if theres alot of carbon build up. Youre gona have to take it apart and clean it.
Old Jul 14, 2011 | 01:30 PM
EvoJoeIX's Avatar
I will pull it apart this weekend and take a look at it. Ill let you guys know if it looks like that couldve been the problem
Old Dec 25, 2011 | 08:50 AM
wally7714's Avatar
I had exactly the same issue, 2 things were bad IAC amd MAS. Now its great.
Old Dec 25, 2011 | 10:59 AM
jc05's Avatar
you ever found out what is was?
Old Dec 25, 2011 | 11:10 AM
wally7714's Avatar
^^^As posted above IAC and MAS
Old Dec 25, 2011 | 11:34 AM
dac001's Avatar
idk does-int sound like this but worth looking at
https://www.evolutionm.net/forums/ev...ease-help.html
Old Dec 25, 2011 | 09:12 PM
dotman05's Avatar
Pull your IAC and turn the key to on, you'll be able to hear the motor working while its trying to find where idle is. I had mine go bad and had a bad idle problem
Old Dec 25, 2011 | 09:46 PM
breeze17's Avatar
mine is doing the same thing right now but if it was ur IAC the check engine light should go on. my cold start idles below 1000 n then once i start driving it idles above 1500 rpm. so gay. also what kind of BOV do u have? i had a guy come look at my car n he said i had boost look through their. good luck keep us posted
Old Dec 25, 2011 | 10:18 PM
CMoney's Avatar
http://www.youtube.com/watch?v=RawRsM_RHRU&sns=em
I'm also having a bad idle. My car stalled everytime I let go of the gas pedal. I ordered a new IAC. Hopefully this is the problem.
Old Dec 25, 2011 | 10:25 PM
wally7714's Avatar
I had almost the same thing but my idle went up to 2500rpms and then to a 300rpm`s and stall. I also had faulty MAS Sensor and EGR Valve was not working properly. Hopefully IAC will fix your problem, seems like lots of EVOs suffer from this problem an any info out there is very helpful
Old Dec 26, 2011 | 01:25 PM
CMoney's Avatar
how were you able to tell that the MAS sensor and EGr had a problem? I started my car today and it idle fine. Odd.. Well
Old Dec 26, 2011 | 01:28 PM
wally7714's Avatar
I replaced IAC and problem remained so basically I spent 6 hours at the shop they just checked and tested everything including the tune and any possible leak to fix the problem.
Old Dec 26, 2011 | 01:31 PM
CMoney's Avatar
Oh man amazingly fast response lol. Yeah I'm definitely going to take it to the shop if the IAC problem doesn't work.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Caino
Jul 9, 2015 07:40 AM
Evo47
May 4, 2015 08:53 PM
Ogrodii
Feb 11, 2015 03:51 PM
JTCB
May 31, 2014 07:22 AM
