max rpm cut for 4G63???
From: Costa Rica with business addres in Miami FL 33166
Hi guys, I have some problems with the lag, due to the big AR of my GT3076 that is .82, my question is, which could be a good cut of rpm??, to run safe, and also to care my crankshaft and not cause damage. A friend told me that raise the rpm cut to reduce the lag and move it to 8200rpm, what do you think dudes?
In this moment I have the stock cut at 7600rpm with clevite bearings, no balance shaft, Evo 9 oil pump, hks valve springs and kelfords 272.
I hope your comments
Raising the limit has nothing to do with lag, perhaps you meant to expand your power band since you are running a .82 instead of .63 like most setups. Yes, you can raise the RPM limit to 8000-8200.
I have lag between shifting gears, if I raise the rpm cut maybe I can reduce some lag between gears. Here in my country I make 11.5 seg in 360mts with lag problems, I have lag since the start and shifting gears.
if anyone knows who has some ATP housing in AR .63 with 3" Vband from one GT3076R maybe someone has removed a damaged turbo and can reuse this part, please I need one.
Thanks for your help, I think the only solution is a smaller housing, Ar .82 is for stroker engines, not for 2000cc unless they are run your rev limit up to 9k
franzcars
Jul 22, 2025 12:26 AM
