3 gauges
Old Jul 23, 2011 | 04:34 PM
asu11's Avatar
3 gauges
Buying the gruppe-s dash gauge pod and as of now i have an aem uego and boost and need 1 more. What would you recommend?
Old Jul 23, 2011 | 04:36 PM
MReBusa's Avatar
Oil pressure, if that fluctuates allot prepare for the worst.
Old Jul 23, 2011 | 04:37 PM
asu11's Avatar
Thats what I was thinking too. Thansk ill prolly get an aem one also to match. Does anyone even use egt anymore?
Old Jul 23, 2011 | 04:38 PM
asu11's Avatar
Now im debating between fuel and oil pressure. Do I need to monitor fuel press?
Old Jul 23, 2011 | 06:24 PM
evo8426's Avatar
No, you will know if the car goes lean because it will show on the Uego.
Old Jul 23, 2011 | 06:40 PM
HN7's Avatar
HN7
Oil pressure for sure. I have Boost, Volt and Oil Press right now, adding a wideband later on.
Old Jul 23, 2011 | 06:46 PM
asu11's Avatar
Oil pressure it is. Thanks everyone. Do I need anything special for install?
Old Jul 23, 2011 | 06:52 PM
Pusha's Avatar
Be sure that whatever gauge you buy includes a sender, if not, be sure you'll be able to source the sender.
Old Jul 24, 2011 | 12:04 PM
wickedjeremy's Avatar
Greddy makes a relocator that will simply screw on to were ur oil filer screws on then ur oil filter. It has ports to were u can screw in the line for ur oil press. That way u won't have to drill n to ur oil pian. Works great!
Old Jul 24, 2011 | 12:23 PM
evo8426's Avatar
No need to buy that either, there are 2 ports on the stock housing that you can remove to install oil pressure and/or oil temp
Old Jul 24, 2011 | 03:03 PM
polish_pounder's Avatar
I have a question. I have an oil pressure guage and it idles at like 10psi and full throttle is like 190 cruising is around 60 is this normal?
Old Jul 25, 2011 | 12:32 PM
Anyone able to tell me if that's normal? Thanks
Old Jul 25, 2011 | 12:41 PM
ProPilot04's Avatar
I could be mistaken, but in the very back of the owners manual I think there are min/max oil pressure values?
I'd check... but I'm at work.
Old Jul 25, 2011 | 12:46 PM
Coney Warrior's Avatar
Not really, EGT is kinda obsolete, I have one in my Eclipse but thats just cause it was in there from years ago, EGT will not be going in my Evo, will be putting wideband instead.
Old Jul 25, 2011 | 01:16 PM
Ok and I mentioned 90psi-110 during wot and 60-70 when cruising
xXVicariousXx
Aug 31, 2016 11:43 AM
D-Train
Nov 6, 2013 02:23 PM
ILikeApples
Oct 17, 2012 06:35 PM
Gruppe-S
Evo 'For Sale' Interior Styling
18
Mar 12, 2009 10:22 AM
fsugatorbait
Mar 14, 2007 06:53 PM
