Evo 8 smoking after kelford 272 Cam install, PLEASE HELP
Old Aug 6, 2011 | 08:27 AM
evo8matt's Avatar
So I installed my kelford 272's and now the car smokes quite a bit at idle.... it smells like unburnt fuel, but it is blue. The car did not smoke prior to this... Everything starts and runs fine, no check engine, no missing or anything.... what could this be?????
Old Aug 6, 2011 | 08:30 AM
MuslimEvoFreak's Avatar
Did you use a blue rtv of some-sort for the cap caps or on the valve cover gasket? It could just be some of it burning off. You also could have dropped some on the manifold while installing.
Old Aug 6, 2011 | 08:33 AM
evo8matt's Avatar
Yes i used ultra black gasket maker, it is coming from the exhaust, no where else
Old Aug 6, 2011 | 08:42 AM
How long did you let the car idle for? If it is still continuous, I would take the valve cover off to inspect everything. You might have missed a step in installing them.
Old Aug 6, 2011 | 08:47 AM
evo8matt's Avatar
i let it idle for awhile each day since install, i haven't missed any steps.. i just dont understand what the deal is with this thing... everything is torqued down proper, ec=verything is bolted back up and all... and if the CAS was 180 deg. off it would throw a code correct?
Old Aug 6, 2011 | 08:48 AM
evo8matt's Avatar
here is a link to a an idle video http://youtu.be/wZ-6ZhrFUrE and it wasn't even smoking that bad here but sometimes it does more than others
Old Aug 6, 2011 | 08:53 AM
Unfortunately I can't see the video at work but if you have the CAS in the wrong way it will not throw a code. Trust me I know! Your car will run oddly though. Mine lost gas mileage and wouldn't idle properly. When I switched it around, I had knock all over the place until I got tuned again. Did you get a tune yet?
Old Aug 6, 2011 | 08:55 AM
evo8matt's Avatar
no i am trying to see if i have something wrong before i take it for a tune
Old Aug 6, 2011 | 08:56 AM
If it's smoking from the exhaust and not the engine bay then take off the valve cover and inspect EVERYTHING once again. Are you getting any noise from the motor? Are your cam caps installed correctly?
Old Aug 6, 2011 | 09:05 AM
evo8matt's Avatar
yes cam caps are all on correct tightened down correct.. only smoke from the exhaust no engine smoke or noise
Old Aug 6, 2011 | 09:31 AM
cfdfireman1's Avatar
Did you do just the cams or did you do valve springs also?
Old Aug 6, 2011 | 09:36 AM
evo8matt's Avatar
just the cams, kelford advised that the 272's work with the stock rev limit on stock valvetrain
Old Aug 6, 2011 | 11:36 AM
BLK_EvIL's Avatar
maby you messed up one of the valve stem seals
Old Aug 6, 2011 | 03:01 PM
evo8matt's Avatar
not possible, never went near the valves, valve stems, springs ect...
Old Aug 6, 2011 | 03:24 PM
Jossue's Avatar
I just installed cams on a friends evo 8 and the rockers can fall off fairly easy double check and if anything if you say you did everything right you might be burning off the gasket maker.
