Noises!!!
Old Aug 12, 2011 | 06:52 AM
projektevo9's Avatar
Noises!!!
Anyone have any idea what these noises may be ill do my best to describe them
1. Clunking noise when turning the wheel side to side (wheel bearings?)
2. quiet pop nois3 when. letting off the gas?
3.loud thump near diff during hard shifts?
4. Probably the most annoying an electric humming that. Fluctuates from high to low pitch when you use anything. electronic ie put up window. Sounds like its underneath?
Thank you
Old Aug 12, 2011 | 07:31 AM
llDemonll's Avatar
1. not a wheel bearing, that would be more like a constant roar
2.
3. if it's rear diff its because of the mustache bar or something like that which comes stock. solid diff mounts will get rid of the noise
4. my guess is a bad electric ground somewhere
Old Aug 12, 2011 | 07:57 AM
Sil'vr-Boi6's Avatar
1. Axles are shot. Are you lowered? coilovers?
2.____???____
3. You guess right----> avoid doing that you'll destroy spider gears or rear diff
4. Change your walbro. But it also be a electric gremlins.
Old Aug 12, 2011 | 08:22 AM
philevo's Avatar
1. axles and/or endlinks
2. motor mount(s). (mine are shot so they make noise getting on and off throttle)
3. rear diff bushing
4. bad ground
Old Aug 12, 2011 | 09:41 AM
Thanks for the prompting responses diff is getting sent away in spring to Shep Transmission as is the Tranny. Might as well upgrade the axles if they are shot any suggestions. And yes it does have bc racing coilovers
Old Aug 21, 2011 | 02:31 PM
Stage2evo8's Avatar
Is the POP noise from number 2 like exhaust pop or under the hood pop
