Bad Crankshaft Sensor?
well i was driving down the road it started up fine. I was at 2,500 rpm going 40mph and the car just shut off. while rolling i tried clutch starting it didnt even try starting. when i got to a stop it tried starting it. It just kept on cranking. Didnt fire not even once. I checked the CEL.. it said, "Crankshaft Position Sensor Circuit" it just keeps cranking and does nothing else.
should i replace the whole sensor?
i have 72k on it now
well to look at it i need to take the timing belt off ect.. was trying to avoid that. just hoping some could think of somthing stupid. The cam angle sensor code didnt come up and it that is bad it would cough or start for a second then stall out i thought
yea u need change it out! it happened it me bro. make sure the crank bolt it tightened all the way... don't take any shortcuts. you basically have to take all the same crap off that you had to during the timing job
