gas problem... help
Old Aug 25, 2011 | 03:05 PM
D_Roo's Avatar
gas problem... help
so my 03 evo is consuming way to much gas now. im like at half a tank by like 60 miles . when it used to be over 100+, and it just started happening.
Old Aug 25, 2011 | 03:10 PM
Mauricio Evo IV's Avatar
Do you have wideband???? maybe bad spark plugs...
Old Aug 25, 2011 | 03:12 PM
D_Roo's Avatar
yeah i got a wideband, and i gotta check them.
Old Aug 25, 2011 | 03:21 PM
which is your AFR in idle???
Old Aug 25, 2011 | 03:24 PM
D_Roo's Avatar
its at 14.6/14.7
Old Aug 25, 2011 | 03:27 PM
Originally Posted by D_Roo
its at 14.6/14.7
Your idle is ok... And your injectors?' what size???
This problem is new in your car?' or you have some time with that problem??
mpls:boost's Avatar
I've been seeing a similar issue, if you find a solution here please let me know.
Old Aug 25, 2011 | 03:31 PM
D_Roo's Avatar
they're stock injectors, and its a problem that just happened, like a few days ago its just been eating away the gas.
Old Aug 25, 2011 | 03:32 PM
D_Roo's Avatar
for sure man, ill let you know.
Old Aug 25, 2011 | 04:17 PM
ReaperX's Avatar
Few things to check:
1: Look to see how much lead is in your right foot
2: Boost leak test
3: Check the spark plugs for fouling
4: If you have cables pull your rom image and see what the target afr's are
My initial guess is that you have a massive boost leak
Old Aug 25, 2011 | 04:33 PM
D_Roo's Avatar
haha number 1, just got a weight reduction.
and i will check the rest
Old Aug 25, 2011 | 05:29 PM
turbotalawd's Avatar
Im gona have to say front o2 sensor on this one.
Old Aug 25, 2011 | 05:37 PM
D_Roo's Avatar
checked the plugs and boost leak test. everything is ok
ill check that front o2
