Rear o2 question
Old Aug 30, 2011 | 06:09 PM
asu11's Avatar
Rear o2 question
Well I am going to order a 3in buschur dp and tp and bolt it up to my works cb. My question is the rear o2 that i believe is in the cat? I have seen that you can delete this with evoscan? Can I just disconnect the rear o2 and it will run fine? Any cons to this?
Old Aug 30, 2011 | 06:31 PM
Spoolin4g63's Avatar
check engine light will be on until you or your tuner disables it
Old Aug 30, 2011 | 06:49 PM
sujinX's Avatar
the rear o2 is after the cat not in it. you can disable it or have your tuner do it. OR you can do this mod which i believe works. basically a defouler but cheaper.
https://www.evolutionm.net/forums/ev...ouler-how.html
Old Aug 31, 2011 | 09:19 AM
evo8426's Avatar
No, it IS in the cat. He has an Evo 9. Yes you can disable it without and problems.
Old Aug 31, 2011 | 09:47 AM
bigguy24's Avatar
... you can do this mod which i believe works. basically a defouler but cheaper.
+1 works great with a test pipe. no problems in 15,000 miles of running it and a tune.
Old Aug 31, 2011 | 10:40 AM
EvoJoeIX's Avatar
i been running it for 55,000 miles and never had the CEL come on. works great and takes like 10 min to make and install
EvilEvolution8
Dec 11, 2015 01:51 PM
stocker77
Nov 15, 2015 05:30 AM
TurbosamVIII
Apr 22, 2013 07:03 AM
momostallion
Mar 7, 2012 04:08 AM
teudmunki9mr
Dec 13, 2009 09:12 PM
