Re-wired DW301 Pump, Do i need a FPR now?
Old Sep 6, 2011 | 11:54 AM
REV.olution's Avatar
I re-wired my DW301 fuel pump and now I'm getting 9-10 afr's @ idle. Because of this my car won't idle and turns off.
Question: is the re-wired fuel pump too much for my FPR? Do need an aftermarket pump. If I do, it's not a big deal, but I'd like to get this issue fixed asap. Tom is tuning my car, fyi, so he'd know how to fix my map if there are other faults.
Thanks.
Old Sep 6, 2011 | 11:58 AM
I also have FIC 1550's as injectors if that helps.
Old Sep 6, 2011 | 01:19 PM
Spec-Ops1's Avatar
You need to be able to see fuel pressure at idle to determine that... If I was a betting man I would say a FPR would fix it...
Old Sep 6, 2011 | 02:02 PM
RSMike's Avatar
and/or a larger return line.
Old Sep 6, 2011 | 04:00 PM
Spec-Ops1's Avatar
You may also try drilling the siphon on the return "Y" inside the fuel pump unit as per TedB's recommendation with the Full Blown DP setups...
Old Sep 27, 2011 | 04:08 PM
Carloverx's Avatar
bump, any resolution?
Old Oct 2, 2011 | 08:46 AM
drb's Avatar
drb
bump for update - did you figure out what the issue was/is?
mrfred
68
Jul 13, 2017 11:22 AM
nor11384
Apr 1, 2017 03:23 PM
whiteEvo08Y
Mar 11, 2017 02:09 PM
Dynotech Tuning
39
Dec 3, 2016 11:04 AM
redralliart04
04-06 Lancer Ralliart How To Requests / Questions / Tips
95
Sep 20, 2008 12:04 AM
