Oil Pressure through the rooF HELP!
Hey guys so yesterday i started my car and normally my Oil PSi guage reads 90-100 on a cold start. well yesterday i started the car and it shot up to 140 and slowly worked its way down. fans came on and everything i let it warm up and it went back down to being normal cruising around 50-60. well i started my car today and again it is way to high up almost at 150. what is going on? i put my BOV back to stock recirc and nothing i dont know were to start so any help would be great.
well if its the temp of the oil turn the car on let it warm up tell the psi is normal then turn the car off then turn it back on to see if the oil pressure is the same if so then you know its cause the oil is cold mine always starts high then goes back to normal when the motor is wamed up
I have a new problem now. i let the car warm up it went back down to normal psi. but i reinstalled my Stock Recirc instead of my SSQV. and now i have horrible transitions from gears it flutters and just sounds horrible i dono whats wrong now anyone have any ideas?
