Dashboard problem
Old Sep 22, 2011 | 12:42 PM
Chriskeatingix's Avatar
Dashboard problem
Hey guys is there anyway to turn up the brightness on my dashboard lights? its is extremely hard to see how fast im going at times
Old Sep 22, 2011 | 12:44 PM
turbotalawd's Avatar
There should be a switch to the left of the steering wheel right under the ACD select button.
Edit: Its right under the left drivers side vent.
Old Sep 22, 2011 | 09:47 PM
barneyb's Avatar
The real fix is to pull the combination meter assembly (aka the dash gauges), remove the main bulbs and pull the blue condoms. However, since these bulbs are on all of the time (high hours), if you mess with them, they are instantly toast. So, go to the dealer, order new bulbs, remove the condoms and install.
Old Sep 22, 2011 | 10:34 PM
EvoJoeIX's Avatar
You can always replace the bulbs with LEDs. It will make it a good bit brighter and you wont have to worry about them burning out. There used to be a dude on here that offered them as a set. Not sure if hes still around or still sells them. Maybe someone else can point you in the right direction
Old Sep 22, 2011 | 11:46 PM
awdordie's Avatar
you could also get trust overlays which are very nice. i have a set and love them. very well put together, and comes with a switch to adjust the bightness as well as switch from a blueish to a green color.
Old Sep 23, 2011 | 09:34 AM
MechTech's Avatar
Just turn up ur dimmer located by ur left shin. idk what hes^^ talking about
Old Sep 23, 2011 | 01:10 PM
black_beauty's Avatar
dimmer only does so much, im gonna order the LED's from superbrightleds.com...
