Egr?
Old Oct 3, 2011 | 06:42 PM
EvoIIIAj's Avatar
Egr?
Quick question guys. Is this where the EGR block off plate goes?
Also, if I block this off will I get a check engine light? I have a JDM Evo VIII.
Old Oct 3, 2011 | 08:25 PM
EvoIIIAj's Avatar
Bump..
Old Oct 4, 2011 | 12:33 PM
partyboy1122's Avatar
Bro, the EGR is located under the intake manifold. It has 2 nipples coming off of it along with 2 bolts.
Here is a good thread for you to read.
https://www.evolutionm.net/forums/ev...-canister.html
Old Oct 4, 2011 | 12:37 PM
1UpMoto's Avatar
If you block it off wont you lose your antilag?
Old Oct 4, 2011 | 12:38 PM
What!?
Old Oct 4, 2011 | 12:39 PM
1UpMoto's Avatar
Originally Posted by partyboy1122
What!?
His evo is not a US spec evo and it comes with factory antilag. If you couldnt tell from the pic he posted.
Old Oct 4, 2011 | 01:20 PM
EvoIIIAj's Avatar
Ok. The thing in the picture then, what on earth is that? Those lines run into my exhaust manifold.
Old Oct 4, 2011 | 01:37 PM
1UpMoto's Avatar
Thats for your anti lag.
Old Oct 4, 2011 | 01:41 PM
Revo15's Avatar
im not sure but if u install the block off plate the check engine light will come on, i think your suppose to use Evo scan to take it out or u can tune it out.
Old Oct 4, 2011 | 04:41 PM
EvoIIIAj's Avatar
Ok, I don't have EGR. I just checked. But can no-one not tell me what that is in the picture that runs to the exhaust manifold?
Old Oct 4, 2011 | 06:18 PM
1UpMoto's Avatar
Did you not read my post?
Old Oct 4, 2011 | 07:03 PM
EvoIIIAj's Avatar
Searching for what you said it looks like its actually called 'SAS'.. Secondary Air System
Old Oct 4, 2011 | 07:10 PM
boostless's Avatar
I don't believe most of the evos outside the US came with an EGR. What you pictured is the sas system, which is there for homologation rules in WRC. If you want to remove it, i will take it off your hands
4RETECH's Avatar
The thing in the picture is secondary air, or what some people here refer to as anti lag.
Only thing is the mitsu setup doesn't really act like the anti lag we know here in the states and WRC. It is more of a secondary air system due to the fact you have no EGR.
Old Oct 4, 2011 | 07:18 PM
EvoIIIAj's Avatar
What are the benefits of removing it?
If i dont need it I'd like to take it out to free up some space
