Missing Alignment Specs
Old Oct 28, 2011 | 08:42 AM
InoNothingMR's Avatar
I went in to get my car aligned today and the shop that did the alignment did not have the stock camber specs for the car. I was curious as to if anyone else has run into this issue? They said they had the latest up-to-date alignment specs in their system and were pretty confused themselves as to why there was no info on it in their system. I did find the specs on EvoM as being:
Front:
Toe-in mm (in.): 0 +/- 2 ( 0 +/- 0.08)
Camber (Selectable from 2 options): -1deg +/- 30' or -2deg +/- 30' (left/right deviation within 30')
Caster: 3deg55' +/- 30' (left/right devitation within 30')
Rear:
Toe-in mm (in.): 3 +/- 2 (0.12 +/- 0.07)
Camber: -1deg +/- 30' (difference between right and left within 30')
I just decided to do my front to -.5 and back to -1.0 to avoid tire wear, but I was curious as to what specs anyone else did theirs to or if anyone else had this issue. The main issue with my car alignment was fixed once the cambers were changed FYI.
Old Oct 28, 2011 | 08:50 AM
EvoJoeIX's Avatar
Stock camber can either be -1 or -2 depending which way you have the bolt in. -1 is where you want it for tire longevity
