FUEL PUMP question
Old Nov 24, 2011 | 06:11 PM
dcamp56's Avatar
FUEL PUMP question
SO i took my pump out and put a walbro 400 in it and hard wired it. I checked the relay under the hood an its good. I also looked at the footwell where the harness clips are and all the wiring is good. I still cant figure why im not getting power to my fuel pump harness!! is there a fuze im missing? or something im being a cadet and not seeing!
thanks
i no the pump works bc i powered straight too it
Old Nov 24, 2011 | 07:23 PM
CurseDSM's Avatar
Check your grounds. Make sure your relay at the pump or wherever you put it is wired correctly as well. I am not sure where the evo pump grounds to being my car had a pump in it already, but I would check that ground for sure.
Old Nov 24, 2011 | 11:26 PM
dcamp56's Avatar
i did...its not like i touched anything! i just took the pump out and it was working b4 it was removed
