Is my throttle body F*@#ed?
Basically... I was installing TB shaft seals, they wouldn't go in, so I lightly hammered the 2nd one in...
PICS ATTACHED if you look closely you'll see it's a little uneven/bent/chipped
ruined the tb shaft seal in the process and I'm car-less until I get this taken care of
Can this be repaired? Dremel? Not sure how "perfect" the throttle body needs to be...
p.s. ignore the fuzzies inside, just concerned about that inner lip area
Doesnt look like you hammered it "lightly". Lol. Anyway it looks like the damage is just on the lip. If anything I would try to file the inside smooth but be very careful. You might be able to get away with just replacing the seals and not have leaks. Put some silicone around the seal too when you install it. Also make sure you do a boost leak test afterward to check for leaks. Good luck.
So what exactly does porting/polishing the throttle body do? What does cleaning it do? Will it make it stick less? Will it improve drive ability? Will it add lots of power?
Is it really worth it to send it out to mil.spec?
I may just clean it myself if that makes a big difference... looks like the throttle body service is just cleaning the throttle body and replacing a few parts.
