question on innovate gauge
Old Dec 9, 2011 | 02:56 PM
Blue_05EVO's Avatar
I searched but could not find what im looking for.....
I've aquired an innovate wideband gauge only!!!!
Question 1: what cable do I need to install the gauge, bc it says it is compatible with 4 different ones
Question 2: can I use an existing o2 hole or do I have to create a 3rd bung hole.....different people have said different things...just want best case scenario.
Old Dec 9, 2011 | 03:16 PM
evo8426's Avatar
you need a sensor and the lc-1
Old Dec 9, 2011 | 04:03 PM
Blue_05EVO's Avatar
Thanks....
Now onto question two!
Old Dec 9, 2011 | 04:20 PM
bigben's Avatar
Originally Posted by Blue_05EVO
Thanks....
I can't remember exactly where on here that I read where to put the o2 bung, but here is where I put it:
Uploaded with ImageShack.us
Old Dec 9, 2011 | 04:53 PM
Blue_05EVO's Avatar
Is it a standard o2 thread....lol....
Honestly thought about buying fouler like I did my cat o2 and just tapping a hole that fits the fouler
Old Dec 9, 2011 | 06:16 PM
bigben's Avatar
That might work too, not sure if not having the wideband o2 sensor in the exhaust flow will alter it's reading. The optimal place for the bung is 3 - 4 inches before the cat (even if you don't have one) and the hole drilled @ 3 o'clock, basically exactly where I have mine in the pic.
This is exactly what I used: http://www.streettunedmotorsports.com/parts/o2_bung.htm
Old Dec 9, 2011 | 07:41 PM
Blue_05EVO's Avatar
I have 3 in open.pipe from turbo back.....and my o2 is right after the joint in the pipes.....hmmmm cool thanks for info
Old Dec 10, 2011 | 03:31 PM
bigben's Avatar
Which o2? There is one in the o2 housing and another behind the catalytic converter (or test pipe, whichever).
Old Dec 11, 2011 | 06:40 AM
Blue_05EVO's Avatar
There is no cat......the exhaust had a hole for the o2 sensor where the original was....
