upper ic pipe popping off
Old Dec 10, 2011 | 02:16 PM
jdubson1's Avatar
Im inna evo viii. My boost is set at 10psi. If I up it at all my upper ic pipe elbow pops off. ne suggestions?
Old Dec 10, 2011 | 02:18 PM
brakeboost980's Avatar
Use to tbolts clamps and spray hairspray on the couplers!!
Old Dec 10, 2011 | 02:20 PM
EvoDom's Avatar
Buy t-bolt clamps
Old Dec 10, 2011 | 02:23 PM
thedru13's Avatar
T-Bolt and hair spray like said above.
Old Dec 10, 2011 | 03:25 PM
bigben's Avatar
Cajun Power's Evo 8/9 complete t-bolt clamp kit with illustration:
http://www.siliconeintakes.com/produ...8faf42c2fd89ba
Old Dec 10, 2011 | 04:31 PM
volkevo9's Avatar
icp
new hose and t bolt
Old Dec 10, 2011 | 04:42 PM
vortico's Avatar
Like all have said t-bolt clamps and hairspray.
If it has popped off alot take a look at the rubber piece and you may want to replace it. If you are going to go and replace it there are silicone pieces can do it while keeping the aluminum bits.
I had that issue and got sick of the rubber hoses popping off so I just bought a UICP from the forums, have not had that issue since.
Old Dec 10, 2011 | 05:10 PM
EVO8emUp's Avatar
You don't need hairspray.
Just clean the hose with a good degreaser and tighten the clamp properly.
Make sure the clamp is placed behind the rolled bead.
Use a ratchet instead of a screw driver. Just make sure you don't over tighten and strip the clamp.
Like mentioned above, t-bolt clamps are the way to go.
Old Dec 10, 2011 | 06:48 PM
DJAfterShok's Avatar
What intercooler pipe do you have? Stock?
Try using T bolt clamps like everyone else had said.... and if its an aftermarket pipe is the end beaded?
I would also try doing a full boost leak test since the turbo is only pushing 10PSI. Just a quick FYI...
KFC-AWD
Mar 24, 2016 09:52 AM
i64X
Evo X How Tos / Installations
138
Feb 27, 2016 03:30 PM
thelza23
17
Oct 4, 2007 03:18 AM
Derek888
Jan 18, 2007 09:29 PM
players234
Apr 29, 2004 08:39 PM
