Fp white
you can run it but you will max out your injectors before you max out the turbo. You might be able to max the turbo with those injectors if your running insanely lean, or using meth or water injection.
The white can flow roughly 10% more than the stock ix turbo and you can max out injectors on the stock ix turbo.
Hope this helps.
Hope this helps.
