Immobilizer Question...
Old Dec 30, 2011 | 04:32 AM
Evo8*'s Avatar
So after many days trying to figure out why my car wouldn't start, a good friend of mine who is a qualified mechanic found my fuel pump wasn't getting power...
...Has anyone ever had a problem with their immobilizer shutting the fuel supply off? In my case, the injectors and fuel pump were not getting power...
Does anyone have the wiring diagram for the fuel pump & relays. Or does any one know where the pump gets its power from.
...Yes, I've tried google...
Old Jan 21, 2012 | 01:40 PM
evopowned's Avatar
im having the same problem with mine right now. already replaced all three relays on mine and car still wont get power to fuel pump. i also cant even connect to my ecu to read it with ecuflash. is yours doing this also?
Old Jan 22, 2012 | 07:08 AM
JakeTheVIII's Avatar
I'm not sure what the immobilizer disables when it's triggered, but it won't start. It's very easy to disable if you have ecuflash...
http://evoecu.logic.net/wiki/Immobilizer_Disabling
Old Jan 22, 2012 | 12:15 PM
MRolla's Avatar
It can be shut off if you know a good tunner he can do this for you, the immobiliser with cause your fuel pump not to come on that the point of it good luck.
