5 codes 335,340,365
Old Jan 8, 2012 | 03:38 PM
451racer's Avatar
5 codes 335,340,365
evo broke balance shaft belt and broke crank sensor. replaced belt and sensor, car starts and idles good. 335, 335 hard,340, 340 hard, 365 happens every time, clear while running it goes on right after its cleared. car stopped and same thing. will not rev above 3000 rpms. Need help. timing marks line up before start, hand turned to check marks and pin in tensioner. Used manual, know 335 and 340. What's 365? Could it be a bad crank sensor, and let it start and run good below 3000 rpms
Old Jan 9, 2012 | 08:59 AM
JohnBradley's Avatar
You have cam sensor problems. 365 is MIVEC so something isnt right there on cam timing. Did you get the trigger plate backwards?
Aaron
Old Jan 12, 2012 | 05:15 PM
451racer's Avatar
Thank you for the help on code 365. Got it all figured out and done. Back on the street and ripping up ****.
