sell the car, or part out?
Old Feb 20, 2012 | 03:47 PM
Sidnakit's Avatar
me too. if you part out let me know
Old Feb 20, 2012 | 04:00 PM
awdturbo8's Avatar
Fix it
Old Feb 20, 2012 | 05:18 PM
ApexIX's Avatar
Did you damage anything suspension wise? Can't tell from the pictures
Old Feb 21, 2012 | 05:11 PM
mission664's Avatar
suspension is fine, i decided to just fix the car once i find some parts.
Old Feb 21, 2012 | 05:53 PM
Mistaken's Avatar
Good! Get her back on the road. Avoid trees.
Old Feb 21, 2012 | 06:09 PM
JACS_06_MR's Avatar
its not that bad, ive seen worse get repaired. you will probably be in it 3-4 k on repairs. you should get a quote before parting it out.
Old Feb 21, 2012 | 06:55 PM
jstelll.'s Avatar
def get a quote before making a decision
Old Feb 21, 2012 | 07:06 PM
lathiat's Avatar
My only advice is that parting out a car takes a LOT of time. :-) Many many many hours not only to strip it, but to pack and send everything.
Old Feb 21, 2012 | 07:39 PM
evo854880's Avatar
if you decide to part it .. pm me..... i am interested in the rims and tires
Old Feb 21, 2012 | 08:17 PM
mission664's Avatar
im not parting out the car, after i get the frame repaired ill slowly get the rest of the parts to get her back on the street.
Old Feb 21, 2012 | 09:24 PM
cmspaz's Avatar
LOL
3-4k? You can clearly see the core support tweaked through the hood gap. New core support will need to be welded in, and a frame rack will definitely be involved. 15mph front-end collisions will kink the frame if the core support moves. Beyond the usual steering/ball joint/control arm failures associated with that kind of accident I wouldn't expect that to have done any damage to the suspension points on the frame, which in my book = fix it. Any frame damage at suspension points = part out, even if the insurance says it's fixable, there's no use in owning an Evo with possibly compromised handling.
Old Feb 21, 2012 | 10:57 PM
Chef-j's Avatar
But how did you lost control?
Old Feb 22, 2012 | 03:04 AM
Toxin's Avatar
Easy fix.
Old Feb 22, 2012 | 04:37 AM
Frew's Avatar
Did you get an estimate on the frame damage?
Old Feb 22, 2012 | 08:17 AM
blowngasket's Avatar
id repair that, its not TO bad. plus nows a good time for some CF fenders and hood. The front framing where the hood runs is gunna be a pain thou everything else looks kinda easy. ACD pump make it out alive? If your looking to do it on budget you can cut and weld the non supportive framing peices under the hood from a donar car, hell ive made my own on a few cars.
