Gauge install
Old Mar 13, 2012 | 03:54 PM
clubEVO93's Avatar
Gauge install
I have defi 60mm water temp, oil pressure, fuel pressure and EGT I was wondering if anyone as a write up on how to install them. Would would it be a good idea to tap the EGT the manifold? or the downpipe? Ive heard both. Thanks Ive only been able to find the install for the oil pressure.
Old Mar 13, 2012 | 07:38 PM
clubEVO93's Avatar
Anyone?
Old Mar 13, 2012 | 07:43 PM
AWDBus's Avatar
egt go's into the manny.
Old Mar 13, 2012 | 07:44 PM
thedru13's Avatar
Ditch the egt and get a wideband. Tap the downpipe. If you are gonna tune the car wideband is the way to go
https://www.evolutionm.net/forums/ev...ple-gauge.html
Old Mar 19, 2012 | 09:09 AM
jrod0187's Avatar
I had my egt tapped in the dp. I'm hearing that's not the best course of action.
Old Mar 19, 2012 | 11:21 AM
evo milk's Avatar
You're probably not getting replies because this subject has been covered many times.
For the EGT you would tap the 2nd runner on your exhaust manifold. I tapped it with the manifold on the car, exactly how evomoto did it. It isn't the best way but it worked, if you're **** just take the manifold off.
http://www.evomoto.com/tech_articles...category_id=16
I'll let you search for the how to on the water temp, oil press and fuel.
