Buschur Stage 2
Old Jan 21, 2004 | 09:02 AM
RenoEvo's Avatar
Question Buschur Stage 2
Ok I'm going to purchase the Buschur Stage 2, but I need some questions answered. Can I install the system myself or do I need to get it professionally installed? Also, once its installed is it a good idea to get my car tuned to make sure everythings working okay? thank you and PLEASE resond
Old Jan 21, 2004 | 10:18 AM
David Buschur's Avatar
Reno,
The parts in Stage 2 are pretty straight forward. The only part that does come with instructions is the exhaust. The rest of the parts are so straight forward that it is just a matter of taking old off and replacing them with the new.
We are also here 9-6 Mon.-Fri if you have any questions when you are doing the install. Do it yourself, it's not to bad.
As for the tuning. Whether you go with the flash we have now or the SAFC the tuning is done. The flash is a matter of taking your ocmputer out, sending it in and then re-installing it. With the AFC you will have to cut one wire, put the other wires in pigtails and then follow the included instructions for setting it up. The tune is as close as you are going to get from car-to-car without using a wideband on the car and tuning it there. I don't find this is needed.
Thanks for the question, hope this helped.
David Buschur
www.buschurracing.com
Old Jan 21, 2004 | 10:23 AM
RenoEvo's Avatar
Dave, can you give me some details on the ecu flash. How much does it cost in addition to the stage 2 system? And how much whp will it put out?
thank you
