Fuel issue HAVE PICS.
My fuel line came off the fuel pump yesterday. (white plastic part the fuel pump goes in) Not sure how that happen. Since I was that far into things I pulled the fuel pump changed the filter/sock. Now the fuel pump has no power. On the fuel pump module connector one pin has burn mark on it like it arced. I used a light test on power is still coming threw that connector. In the pic below is the fuel pump module connector the two circled have power. The one circled with three connectors has power with key in the other has power only when turning over the motor.
http://s1159.photobucket.com/albums/...ent=IMG016.jpg
Fixed it. The EVO is alive and running. I took everything apart again and pushed, pulled, wiggled every fuse, wire, and hose. I then tetested the pump with direct 12v. It worked so I put it all back together and it started right up.
