Injector setup
Old Apr 28, 2012 | 11:59 AM
617APEXCT9A's Avatar
Injector setup
im going to run a bigger injector setup for a mild turbo setup, the turbo im going to run is a tomei turbo charger. has anybody run these FIC 750cc High Flow Fuel injectors in there setup, if so i need some info on the good or bad?
Old Apr 28, 2012 | 12:04 PM
SW20Mike's Avatar
Veteran: Air Force
Those seem a little small for an upgraded turbo, never seen anyone run a Tomei but why not go bigger? I personally purchased FIC 1050cc injectors and I'll be running an Evo 9 turbo, GSC S2 cams and bolt ons. Give your self some room to grow. Also I assume you are going to run pump gas?
