Transfer case just doesnt want to go on nicely..
Old May 10, 2012 | 08:00 PM
Mobrown's Avatar
ok so i decide to do the job by myself and on my garage floor( I know bad idea) it wasn't really that bad with loosening the sub frame and using a cherry picker. So i got my new clutch on and trans installed. Now the major problem is my transfer case, i can throw it up on there and it slides on the splines and dowl pin, but it stops with about a 1/4 gap between the tansfer case and trans. I tried tightening it up carefully and got nowhere. Any help or tip at all would be greatly appreciated
Old May 10, 2012 | 10:04 PM
Graphic's Avatar
I used a weighted rubber mallet to tap the t case on a bit after I knew for sure everything was properly lined up. Get under the car and tap it around and do the same for the top.
I then put all the bolts in and worked my way around each bolt making sure not to put very little stress on each bolt as I did this in a rotation kind of like the pattern of wheels or head bolts so the tcase wont go in **** eyed or cause too much stress on any part of it. The transmission and t cases on these cars fit pretty snug.
FYI: I generally don't prefer this method and always try any other way before I use bolts to walk a part on. This can be dangerous to the part if you don't know what you're doing.
Old May 11, 2012 | 06:48 AM
CtSilver03Evo's Avatar
Might be a stupid question - but did you already install the output shaft that goes through the driver's side transmission? If so, that will do it! If not, try doing what graphic suggested.
Old May 11, 2012 | 07:08 AM
Initial_r90's Avatar
when all else fails .....BFH
Old May 11, 2012 | 12:31 PM
ppremier21's Avatar
I did mine about 3 times within a month and that gap was always there....i just went around tightening the bolts little at a time and it slowly closed
Old May 13, 2012 | 11:31 AM
CharlieGsanD's Avatar
hand tighten all T/C mounting bolts so the heads sit flush on the T/C. then wiggle the T/C gently. it should pivot off the bolt heads & slide on slightly (1/8"-1/32"). repeat the process until the T/C is flush with the Trans.
Dallas J
Sep 10, 2019 11:45 AM
Ginglingston11
For Sale - Part Outs
May 8, 2016 06:19 PM
09Ralli
Sep 19, 2015 06:24 PM
daracer18
May 12, 2008 06:55 AM
Adamk24
24
Aug 3, 2007 08:46 AM
