Which sensor is it?
Old May 30, 2012 | 12:38 PM
CtSilver03Evo's Avatar
Which sensor is it?
Can someone please tell me what the name of the sensor (or component) is that is on the back side of the intake manifold? The sensor I'm referring to has two vacuum lines that attach to it as well. Thanks.
Old May 30, 2012 | 12:54 PM
06RedRalli's Avatar
Egr. Is it below the throttle body as well?
Old May 30, 2012 | 02:22 PM
jrblackSE's Avatar
which sensor are you referring to on this thread?
https://www.evolutionm.net/forums/sh....php?p=4549262
http://i87.photobucket.com/albums/k1...g?t=1184714659
The only sensor on the back side of the intake manifold with two vacuum lines connected to it is the EVAPORATIVE EMISSIONS PURGE SOLENOID. You will see on the vacuum diagrams on the links above. I hope I have provided some useful information for you. Good luck.
