Problem with my Evo
Old Jun 26, 2012 | 05:18 AM
EvoIIIAj's Avatar
Originally Posted by 1d10t
If it were the thermostat, it would overheat. Just common sense.
Make sure you have all of the air out of your cooling system.
I raise the front of the car up on Jack stands. Take the rad cap off, fill it up. Start your car. Let it run until the fan cycles twice. Which indicates operating temp. While its running keep an eye on it, and keep it full. It will over spill.
After the fan cycles a second time, and the radiator is full, put. The cap on.
Lower the car. Drive and test after cool down.
The cap controls the pressure. Something may be failing on the purge side.
Could also be a head gasket. There are tests you can buy, that test your coolant for exhaust
Well, I did it this way yesterday evening and went for a drive last night, went to feel the upper hose this morning and it was pretty much soft! This is unbelievable lol.
Evoryder
Apr 29, 2019 10:09 AM
EvoCop
Evo X How Tos / Installations
14
Jul 11, 2015 11:09 AM
<mojo>
Lancer Troubleshooting
12
Nov 12, 2012 02:07 PM
TeachersEvo
Jul 31, 2012 06:54 AM
Lucas03ES
Aug 2, 2010 12:16 PM
