Help Trying to install injectors.
Old Jun 29, 2012 | 05:25 PM
Charlie-Y's Avatar
Hello , so far i was able to pull out the fuel rail but lost one of retainer clip of a injector,
Anyway i just want to make sure these injectors seat properly onto the fuel rail.
These are fic 1050cc , about the blue grommet , do i push the injectors all the way into
The fuel rail crushing the grommet ?.
Old Jun 29, 2012 | 05:52 PM
CDrinkH2O's Avatar
I've got the FIC1050's and didn't need to push the upper grommets all the way in. They are designed like an accordion to provide some positive spring to hold them in postion once you tighten the fuel rail back down. Don't forget to use some motor oil on the lower seals as they are very easy to nick = instant boost leak and increased chance of an engine fire
Old Jun 29, 2012 | 06:55 PM
Charlie-Y's Avatar
Oh....okay
Old Jun 30, 2012 | 11:12 AM
Charlie-Y's Avatar
If i dont push it all the way in , the damn injector keeps falling off the fuel rail while im trying to install the rail back on to the engine wtf.
Anyone have any tips?
Old Jun 30, 2012 | 12:13 PM
Dmav1989's Avatar
I lubed the bottom seal and set them down in the engine and then i lowered the fuel rail down on the heads of the injectors and the secured it down
Old Jun 30, 2012 | 06:51 PM
Charlie-Y's Avatar
Ohkay, I putting it in as a whole piece .Ended up removing alot of things out of the way.
Old Jul 1, 2012 | 11:23 AM
Charlie-Y's Avatar
Update !
I've installed both the walbro and injectors , plug the fuel lines both at the pump and the ones in the engine bay , start the car let it run for 3mn and check for leaks but bone dry.
Today i took my evo out for a spin , but something is wrong, the car bogs and a hissing noise from the engine bay , while parking car idle and rpm fluctuates up to
3k. No fuel leaks or smell either.
power loose at high rpm while driving.
Allthis sounds like boost/ vacuum leak but with no black smoke from the tail pipe.
Keep in minde that the car is not yet tuned.
Any tips where the culprit my be?
Old Jul 1, 2012 | 03:10 PM
clubEVO93's Avatar
Are you tuned for your new injectors sir?
Old Jul 1, 2012 | 03:17 PM
Charlie-Y's Avatar
Update !
No not yet , it may run rich , but should i be able to drive it?.
Old Jul 1, 2012 | 03:46 PM
06RedRalli's Avatar
It most def will run rich. Do not drive it, running rich for a period of time can wash out the cylinder walls causing problems.
Old Jul 1, 2012 | 04:09 PM
Charlie-Y's Avatar
I want to know if this is a symptom of a untune car on 1050cc injectors and walbro,
Or something else that i did not put it back together right.
Old Jul 1, 2012 | 04:19 PM
Boostevo58's Avatar
Tune now!!!!!
Old Jul 1, 2012 | 04:25 PM
Charlie-Y's Avatar
how the heck i am going to drive 30 minutes to my tuner in this condition.
Old Jul 1, 2012 | 04:27 PM
clubEVO93's Avatar
I would remove the injectors and then put the stockers back in until you have time for a tune.! Unless you can get an email tune from a well known tuner.! But stop driving it unless you wanna put alot of money into things. GL
Old Jul 1, 2012 | 04:36 PM
silverIXMR's Avatar
those are pretty popular injectors, search evom for the scaling and latencies and plug them in or see if your tuner can email you a map with those values changed just to get you there. I have fic 1100's and they were extremely easy to dial in, took my tuner about 5 minutes to get mine dialed in near perfect. otherwise put your stockers back in and drive there, now that you know how to install them it shouldnt be a big deal either way
