recommendation for head gasket for evo 9
Old Jul 26, 2012 | 11:22 PM
hachansoo0413's Avatar
Hello EvoM!
I'm about to install S2's/beehive springs with titanium retainers/head studs.
Should I replace the head gasket ?
If so, which one do you guys use?
I will stick with stock turbo for couple months.
BTW what is the stock head gasket dimensions ?
is it bore 86mm / thickness 1.3mm ?
Thank you!
Old Jul 27, 2012 | 04:47 AM
boostleak's Avatar
Might as well if your going to be removing the head to do the studs. Oem head gasket is the way to go. proven to handle alot of power.
Old Jul 27, 2012 | 05:06 AM
gsrboi80's Avatar
OEM for sure
Old Jul 27, 2012 | 05:17 AM
CtSilver03Evo's Avatar
Originally Posted by gsrboi80
oem for sure
+1.
Old Jul 28, 2012 | 01:48 PM
reboundicon's Avatar
When it comes to engine components like timing belt, water pump, head gaskets etc. OEM is always the best choice.
Old Jul 28, 2012 | 06:39 PM
Thanks for inputs guys!
Im going with OEM
