Crankshaft angle senor???
Old Jul 26, 2012 | 11:44 PM
AEvans190's Avatar
I am in the process of replacing my timing belt/balancer belt am made a mistake. The tensioner for the balancer shaft belt was positioned too close to the crankshaft sensing blade. After I hand cranked the engine, the blade was bent from the tensioner and as it passed through the crankshaft angle senor it was scraping.
I am replacing the blade, but I am wondering if I should replace the crankshaft angle senor?? I saw a tiny bit of shavings in side the sensor where the blade passes though and was able to clean it out.
Also the balancer belt was a little chewed up on a couple lips from the bent blade hitting the belt...
Should I replace everything that was damaged??
I tired bending the blade back to straight but it was not the same. It was still rubbing on the sensor.
Old Jul 27, 2012 | 07:00 AM
user 0284092234's Avatar
It would probably be worth it in the long run...CASs are pretty cheap
Old Jul 27, 2012 | 11:58 AM
bafhoops89's Avatar
That's funny. I'm doing my 60k and this same exact **** happened. I'm replacing the blade and sensor. Also have to replace bs belt.
Old Jul 27, 2012 | 12:08 PM
RoMeIX's Avatar
I would go ahead and replace everything that was damaged while you are working in the area anyhow. Better safe than sorry, right?
