how to tell if tob clip popped off?
Old Jul 27, 2012 | 06:27 PM
420a-t's Avatar
Im installing my tranny in my car and have it all bolted up. i pulled on the clutch fork towards the drivers side of the car and it pops a little everytime i pull on it now, should i not have pushed it that way? the clip appears to still be on via the inspection hole, but i want to make sure its good before i finish the reassembly.
does it pop off from where the TOB attaches or from where the clutch cover attaches to it?
here are some pics:
heres where the clutch fork is resting if that helps at all too:
thank you
Josh
Old Jul 27, 2012 | 09:15 PM
420a-t's Avatar
Also, if i pull the fork towards the drivers side i can pull it all the way, but it clicks once when i do it, does that matter? the fork is resting in the middle of the "fork hole" if that makes anymore sense too.
i just dont want to put this all together and have to take it back out right away because of this.
thank you
Josh
